Type what you are searching for:
Edge Exposure
Edge
Exposure
Create subtle edits along the edges of images.
$4.99
Add to Cart Learn More
Available within Topaz Studio.
The Little Things.
The Topaz Studio Edge Exposure Adjustment is perfect for subtle changes that enhance edge color, correct edge detail, and add highlights.
Make it Count.
The Edge Exposure Adjustment allows for subtle, yet powerful edits along the edges of images. Increase drama with dark edges, add highlights with white edges, or enhance images with various colors. With 4 edge options, 3 exposure controls, and a range of colors to choose from, you can enhance image edges quickly and smoothly.
Intensify Images.
This versatile and straightforward adjustment allows users to manipulate and control the edge highlights, shadows, and colors of an image. Easily add faux light sources to image edges, shadows along borders, and colors to enhance photographs. The Edge Exposure Adjustment also allows users to correct edge detail and to add transparent gradients that accentuate images.
Topaz Studio - Edge Exposure Adjustment
Before and After using the Edge Exposure Adjustment
Create subtle edits where it really counts using the Topaz Studio Edge Exposure Adjustment.
Get Topaz Studio Free!
Get started with this awesome adjustment completely free for 30 days! You’ve got nothing to lose.
LEARN MORE
Training and Tutorials
Adjustment Introduction
The Topaz Studio Edge Exposure Adjustment allows you to add faux light sources to image edges, shadows along borders, and colors to enhance photographs.
The Topaz Studio Edge Exposure Adjustment is a great way to add the perfect finishing touches to an image. With 5 easy-to-use sliders and independent control of each side’s edge exposure, you have complete control of the outcome of the edge exposure.
The sliders and what they do:
1. Edge Icon:
The edge icon lets you independently create custom edge exposure for each of the 4 sides of your image. Select left, top, bottom, or right to effect only that edge’s exposure.
2. Exposure:
This slider controls the edge exposure of your image. Simply increase the value of the Exposure slider and the image’s edge will become darker. By decreasing the value, the image’s edge will become lighter.
3. Size:
The Size slider controls the overall size of the edge exposure. Increasing the value of this slider will increase the size of the edge exposure, while decreasing it will decrease the size of the edge exposure.
4. Transition:
The Transition slider controls how smoothly the edge exposure will transition into your image. Increasing the value of this slider will create a softer, more subtle transition.
5. Color Strength:
The Color Strength slider controls the strength of the color of the edge exposure. By default, the color will be black. Increasing this slider will increase opacity of your edge exposure, while decreasing this value will decrease the opacity of your edge exposure.
6. Color:
The Color slider allows you to choose the color of your edge exposure increasing this slider will shift the color to the right, while decreasing this value will shift the color to the left.
RELATED PRODUCTS
