Type what you are searching for:
Black and White
Black and
White
Create dynamic and dramatic images.
$14.99
Add to Cart Learn More
Available within Topaz Studio.
Dynamic and Dramatic Photographs.
Other editing programs, such as Photoshop, allow you to desaturate images.
The Black and White Adjustment in Topaz Studio has the ability to augment and change each color channel separately, allowing for perfected edits.
Dramatic Effects.
The Black and White Adjustment makes transforming color images into dramatic black and white images simple and precise. Users have the capability to change and perfect 9 different color channels and can control the image brightness and details in this adjustment. The ability to use the Suppress Artifacts and Color Sensitivity sliders ensures that the proper color range is affected while editing.
Traditional Yet Versatile.
The high range of adjustment possibilities allows users to transform any color image into an elegant black and white photograph. The results are graceful tonal transitions that metamorphosizes images into dramatic photographs. The ability to suppress artifacts allows for smooth and natural tonal transitions and edges.
Complete with 9 different colors bands, 4 refinement controls, and the Topaz Studio full range of masking options, you can transform any photograph into a stunning black and white image.
Get Topaz Studio Free!
Get started with this awesome adjustment completely free for 30 days! You’ve got nothing to lose.
LEARN MORE
Training and Tutorials
Adjustment Introduction
Other editing programs, such as Photoshop, allow you to desaturate images. The Black and White Adjustment in Topaz Studio has the ability to augment and change each color channel separately, allowing for perfected edits.
Color Bands
9 Color Band Sliders:
The Black and White Adjustment contains 9 Color Band Sliders, allowing for complete control over image conversion. The adjustment analyzes images and assigns a color value to each and every pixel within an image. These color values are then collected and organized into 1 of 9 different bands, 1 for each color and 1 for no color, or Gray. For precision edits, adjust the slider to change one color band at a time. Moving the slider to a value of 1.00 will lighten the color band and moving the color band towards a value of 0.00 will darken that color region.
Refinement Sliders
1. Brightness:
Make the overall image as light or as dark as you need.
2. Details:
The details slider allows you to pull out details or soften your image.
3. Suppress Artifacts:
Smooths artifacts for a natural and organic color transition, no matter how extreme your changes are.
4. Color Sensitivity:
Expands the original color range selection to expand or narrow the affected areas of tonal change.
RELATED PRODUCTS
